another ?, intake removal - LS1TECH
Thread Tools Search this Thread
Old 03-14-2017, 08:17 PM   #1
Default another ?, intake removal
when you remove the intake after all the bolts are removed (except the back 4 of course), do you lift up as high as you can and then pull forward about 6 inches or so (to get the MAP sensor and small vacuum hose removed) I'm pretty sure since this is my first time removing the intake, I'm going to break the OPSU. Also upon reinstalling, maybe have the OPSU socket on the sensor to help prevent breaking the sensor until I get the routing of the brake booster hose in place.
blue09rocket is offline   Reply With Quote
Old 03-14-2017, 08:40 PM   #2
Yes, you do lift the intake and pull it forward to remove the lines in the rear. I don't think there is much danger of damaging the OPSU if you're careful. It's actually well behind the intake and out of harms way. Just take it slow and try not to bump things when working. Reinstall it the same way. Once the hoses and connections are back in place, set it back into position and bolt it down.
unit is offline   Reply With Quote
Old 03-15-2017, 08:19 AM   #3
Rise of the Phoenix's Avatar
I just removed my LS6 intake and replaced it with a FAST intake, and it was my first time removing the intake. It really wasn't too bad. You are correct in that you will need to lift up and pull the intake forward in order to reach the MAP sensor and vacuum hose. I didn't even realize there was good chance of breaking the OPSU until after I had already done the swap. I guess I got lucky and didn't break mine because when I started the car up after the swap, my oil pressure gauge is working like a champ.
It was a pain in the *** trying to get the last 4 back bolts to stay up when trying to remove/pull the intake forward. If you have a couple big rubber-bands, you can put them on the bolts (one rubber band will go from one bolt to the bolt directly across from it, hence why you'd need two). This will allow tension to be placed on the bolts and keep them from dropping back down.
Rise of the Phoenix is online now   Reply With Quote
Old 03-15-2017, 09:45 AM   #4
Red4Mula's Avatar
Quote:
I've done mine twice so far, it's not too bad, but that is a great idea about using the rubber bands to hold the bolts up.
Red4Mula is offline   Reply With Quote
Old 03-15-2017, 11:31 AM   #5
Quote:
I didn't think about doing that until after I already got the intake off. I fought with it for a few minutes, but it wasn't too bad. It would definitely help though.
Old 03-15-2017, 07:20 PM   #6
thanks for all the help, just when I saw pics of an LS1 engine from the rear, it looked like when looking at it from the front, it was the intake, the OPSU and then the brake booster hose. Here is a pic I just found, pic credit goes to 97ss497
Old 03-19-2017, 10:31 AM   #7
Do like I did and get the $60 parts from jegs to do remote mount for the sensor. I did this three years ago and never have to worry about breaking it again
warriorpluto is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
opsu relocation blue09rocket General Maintenance & Repairs 6 02-26-2017 11:07 AM
LS1/LS2/LS6 intake swap Sticky!!! DavidGXP LS4 Performance 213 05-03-2016 08:42 PM
OPSU leak? Sweet_SS Generation III External Engine 0 04-23-2015 09:34 AM
how do you remove these fittings (Oil pressure sensor) 1995blacktattop LT1-LT4 Modifications 46 04-02-2015 06:24 PM
Oil Pressure Sending Unit ??? Moose67 Generation IV External Engine 5 08-21-2010 11:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
