Looking for a new x/y/h-pipe
I've got the fabulous Grot y-pipe with the ball'n'flange style collectors. It sounds like the driver side cat took a dump and I'm considering replacing the whole y-pipe with something better.
I'm leaning towards dumping the cats so long as it doesn't cause rasp, resonance, or any other noise anomalies inside the car. I had wanted to get a SLP dual/dual. But if I need to replace the y-pipe, I'd like to go with an X-pipe.
Effectively I'm looking for a catback setup with a X-pipe which will be very similar in all operation to the D/D.
Recommendations?
Recommendations?
Well, you had carsounds in there, any specific reason you want to dump them? Imo the more refined noise, less gas smell, and no rasp all outweight the ~10 hp you might gain, but that's just a thought. No cats don't sound great with a y-pipe catback configuration in almost any car.
Anyway, if you decide to go with a x-pipe, you would have to plan for true duals dumped at the axle or out back, that would sound $ perform good even catless but you inherite the little characteristics of TDs...the x-pipe dictates what exhaust you need to run from that juction back.
One budget option you have is to get someone to fabricate a custom-Y pipe to fit your Grotts and catback you already have, and put on or not put on cats at the same time. This would run under $100 most likely and should as consistant as the other setup if you decide to go that direction.
My current catback is stock with a cutout.
I'm leaning towards no cat's just due to cost. If I was to get cat's I suppose I'd want the highest flowing variety, which I think are still the RT 703000's. But $500 for cat's? Hmm...
How long can I get by with a cat in this condition? If I can save up for the RT's, maybe I can have a local shop fab something up for me. Trting to swap out this stock cat-back for a dual/dual, too.
