Prob after header install HEELP!
I installed my "new version" pacesetters on my '98 formula this weekend. I drove the car with just the headers and cats for an hour or two around town and on the highway for fun with no problems what so ever. Later, that night it started to rain and I took a buddy for a spin around the block. I went through a really big puddle and a couple seconds later, the car almost almost stalled. I checked the codes and got 1/1 and 2/1 oxygen sensor codes.
The next day, I hooked up the passenger side exhaust but couldn't finish both sides without a welder so I drove it with open driver side exhaust.
I checked the codes again and only got a code from o2 1/1
So I figure that the addition of the rest of the exhaust pipe must have helped out the passenger o2 sensor with some back pressure or something. So today, I get the driver side hooked up and I still have the problems with it running fine then crappy, restart the ign., runs fine then crappy.
Ever since then: the car starts up no prob and idles smooth like a champ. As little as 30 seconds later, it'll start having problems idling.
When I drive, it'll go no problem for at least 30 seconds and then it'll bog down and be crappy. If I just flick the key off/on with out stopping the car then it'll be fine for another little while.
I'm getting a high voltage from o2 11
I spliced the o2 wires with but connectors (they're on there good) I spliced them in between the weatherpak connector and the sensor. Is that alright? I'm not getting any errors from o2 2/1
Does the car ignore the o2 sensors for the first 30 seconds?
I'm gonna go disconnect/reconnect the battery and see what happens.
I bought an o2 sensor but I don't wanna use it if I don't need to.
There's a lot of crap here but hopefully someone can help me out!
Originally Posted by kenkaru
I hope that's it. I still have one of the after cat o2's I can swap in there.
thanks for the input!
