Mechanical Water Temp. Guage
1 Post
Originally Posted by bcrishon
Where is everyone tapping into the motor for a mechanical water temp. guage??
The above two posts are for electrical gauges. You don't want a mechanical. It means you have to run a coolant line directly to the gauge. The electrical ones are only about $50, and for the water temp the best place is above the starter in the block. You will need an M16x1.5 adapter.
If you want to know what the water temp is leaving the motor, drill and tap a hole in the top of the water pump.
http://frrax.com/rrforum/index.php?a...hl=water+pump&
Most of the Speed World Challenge Vettes I've seen do this.
A 5/16" drill bit and a 1/8" NPT tap is all you need ...
