Anyone port their stock MAF housing's?
I read the article at www.installuniversity.com and thought i could do it myself. Anyone here do it? is it hard at all? any noticable gains? Money is tight soo anything free i'm willing to do
I just descreened it? I wouldnt mess around with any of that MAF sensor bullshit to be honest with u. Id rather play it safe than sorry. But thats just me.
haven't heard of any noticable gains from doing this. stocker is good into the 400's. it probably wouldn't yeild enough power and could cause some problems, but tahts usually with A4 cars from what i hear.
Id skip that. port your TB and gain some power and get better throttle response.
I heard about problems with A4 cars after porting and/or descreening the MAF. How true is this? I just descreened mine (MN6 car) and noticed a very slight increase in the range that the LEDs in my Air fuel ratio meter. Not anything alarming though, In fact I think it went back to normal after running a bit lean after the LT install.
If you're not going to have the car tuned, don't mess with the MAF. Porting/descreening the stock MAF throws the calibration out of whack - more air gets through then is metered.
If you get a tune to correct for it, then there is some worth to freeing up some airflow around the MAF, maybe a few extra ponies, but nothing major.
I'll start by saying: I ported mine, hogged it way out and mirror polished it. Did it way back before anyone realized it caused problems.
Don't do it.
It does make power, but the risks and headaches are not worth the trouble.
Don't descreen either!
As a matter of fact, that is where alot of the harm stems from. If I could go back and port mine again, I would have ported it with the screen in place!
There are tricks and tips to getting the mod to work and make power... but they are many and cost money.
I got my bugs worked out over time, I have an M6, but it was a headache.
Don't do anything to the MAF on an A4. The MAF readings are used to regulate the tranny line pressure. When the readings are skewed, you damage the tranny.
Fair warning:
Don't bother.
Dave
Don't do it.
Fair warning:
Don't bother.
Dave
Captain Double Post
The only thing I did to my maf was I polished the out side because I polished my tb on the outside and I wanted it to match didn't mess with porting anyth ing not worth the risk. But I tell you it took me a long time and I still have to go back and touch up a few spots but for apperance polishing those 2 things looks great, ill try and get some pics up to show you guys
