broken flange bolt?
broken flange bolt?
like the title says i broke the bolt that holds the y-pip on the driver side. how do i remove that bolt to replace it. i was going to install the gmmg and the pipe that connects to the y-pipe was welded so i was going to remove the whole y-pipe and grind down to remove it. while in the process i then found out the y-pipe is alo connected to the cat on the passenger side so more bolts would have to be removed.
so can i just purchase that bolt to replace and can a exhaust shop have that bolt. now im driving to the muffler shop with no muffler.
another 100.00 for install
