Intermittent Charging with "Overdrive" Alt Pulley???
Old 07-21-2004, 07:51 AM
haole_boySS's Avatar
Default Intermittent Charging with "Overdrive" Alt Pulley???
I just put on the March fluid underdrive pulley and it came with a "overdrive" alternator pulley. (its about half the size of stock so I assume its an Overdrive)
I am having intermittent charging issues now. The last few times I started the car it would idle on battery till it found the idle. It is taking an average of 35-45 secs to start charging. I had an ASP pulley before with the stock alt pulley and never had an issue.
Has anyone ever had this happen before???
Any help is greatly appreciated.
Andy
Old 07-21-2004, 10:24 AM
MyLS1Hauls's Avatar
Wonder if the belt is slipping on the new alt pulley due to less contact area.
Old 07-21-2004, 11:36 AM
I thought about that. maybe I could paint a line on it to see if it is spinning. The tensioner is right inbetween both stops so its good and tight. I just hate to go buy another belt with the hit or miss length crap.
Old 07-21-2004, 02:37 PM
TTT Please
Old 07-21-2004, 07:52 PM
Another_User's Avatar
Sounds like your alternator is about to crap. Use a multimeter and check the voltage while your car is running. Unless.....are you sure you torqued your pulley on all the way? That would explain it.
Old 07-22-2004, 01:09 PM
Is it possible to over spin the alternator and kill it? I am going to put the stock alt pulley on tonight and see if that fixes the problem. Maybe the alt pulley is so small that I need a shorter belt to tighten it up some.
Old 12-19-2004, 09:55 AM
Michael Ozorowsky's Avatar
I'm curious of this as well.
Old 12-19-2004, 10:19 AM
I just had a stupid thought. Your alternator pulley could have come loose and be spinning freely.
