another pulley question.
Old 07-28-2004, 09:10 AM
frey51's Avatar
Default another pulley question.
I am looking for a straight forward answer to my question, because I cant seem to find one.
I want to get asp pulley(s) but dont know what to get. I dont have a stereo or use my ac (alot) so electrical drain probably wont be a big problem. Also it is an M6.
Basically, what pulley(s) and belt(s) should I get to net the most hp gain?
I need to replace at least one of my idler pulleys soon because it is making very loud bering noises. So I want to toss on the asp pulley(s) then.
Fry
Old 07-28-2004, 09:26 AM
HumpinSS's Avatar
All of the pulleys will net about the same gains you will wnat to get the CRANK PULLEY. IMHO I would go witht he march from thunder IIRC it comes with bolts and belts. If it doesnt they can send you some for 20.00 (belts) 3-5 for the bolt.
Hope this helps
Old 07-28-2004, 09:39 AM
frey51's Avatar
I have been able to find more good reports/experiance with the asp's than the march. I think I am just going to stick with the asp. So I should just get the crank pulley, crank bolt, and belts to match the crank pulley? What about the alternator pulley, etc.?
Thanks
fry
Old 07-28-2004, 09:48 AM
HumpinSS's Avatar
you dont need it. I ran my m6 for 4 years without a alt pulley and didnt have any issues. I stil have my radio and all accesories in the car.
Where have you heard bad experiences about the MArch can you provide any links
Old 07-28-2004, 10:02 AM
GregWS6&z28's Avatar
ASP is a great pulley. I got .17 off my ET with only crank alone. No charging issues since I didnt ge the Alt pulley.
Old 07-28-2004, 10:20 AM
frey51's Avatar
HumpinSS: I havnt heard bad things about the march, just not much information other than people saying buy it...sorry for the confusion. I have just found more indepth experiances about the asp.
Greg: what other mods did you have when you put on the pulley? Also What belts do I need with just the crank pulley, and where did you get it and what did it cost?
Fry
Old 07-28-2004, 10:45 AM
01 Red WS6's Avatar
I got the alt pulley too but I dont use it, I dont have any issues with the charging. I would just go with the crank pulley
Old 07-28-2004, 11:21 AM
cyphur's Avatar
you need to get all the belts that go on the crank pulley, since its going to be a difference size pulley its going to need different size belts. the belts are sold in packages generally, or when u do order the part, CALL and order it, that way you can talk to whomever you're ordering it from so u make sure you get everything you need. most every decent race shop knows exactly what all you'll need.
Old 07-28-2004, 11:49 AM
frey51's Avatar
I need a new crank bolt too right? Its not smart to use the old one?
Old 07-28-2004, 12:12 PM
HumpinSS's Avatar
Yup definately need a new crank bolt. They are torque to yeild bolts and can ONLY BE USED ONCE
Old 07-28-2004, 12:36 PM
frey51's Avatar
thanks for the input fellas, much appreciated.
Fry
