OBD2 code P1133 02 sensor but which one
Old 09-28-2004, 08:56 PM
ArticZ's Avatar
Default OBD2 code P1133 02 sensor but which one
Well atleast I think its a 02 sensor P1133 says HO2S insufficient switching bank 1 sensor 1.. is there away to tell which sensor it is?
Old 09-28-2004, 10:16 PM
7 Second Club
NicD's Avatar
bank 1 sensor 1 is the front driverside O2. That code means the O2 may be dying off or not getting hot enough.
Old 09-28-2004, 10:37 PM
ArticZ's Avatar
should I just change out the sensor then.. or what else can be done?
Old 09-29-2004, 12:31 AM
7 Second Club
NicD's Avatar
Try swapping the two front sensors, clearing all codes, and see if the code follows it to bank 2 sensor 1. If so the O2 is dying and just needs to be replaced.
Quick Reply: OBD2 code P1133 02 sensor but which one
