Edelbrock Victor install afterthoughts.
Ok, heres the afterthought after its all said and done Removal of old stuff took 4 hours. Installation of new took 30 mins. I swear to god, the headers both slid in from the bottom with the car about 2 ft off the ground. just a lil bump on the bottom and they both popped in. Had both headers bolted in with plugs and wires attached and ready to go in 30 mins. The y pipe is slip fit, and i slipped it and clamped it to wait for a welder. I had my 02 bungs welded into the Y pipe, and I removed the rear 02s. The whole package was a true bolt in. Only fabrication needed to thE I pipe to make it shorter to fit the Y pipe. This is bar far the best header system for the buck. 550 shipped, you get everything you need extensions,gaskets,bolts,air/egr fittings if you so chose to install them. They install with ease, and everything fits, no banging! seat of the pants is huge. The merge collectors really help scavenge that exhaust. I have no rasp through my hooker catback. Just clean sound. I have 305's in the rear, and I couldnt even spin the tires while rolling in first before the headers. Now I can go all the way through 1st and halfway through second roasting them. Great headers, great fitment. Glad I waited.
