Ypipe w/o cats, any gains?
yea, i got the cutout and stock everything else.
getting rid of the cats getting a better pipe to replace where the stock one flattens out should do 5-8 rwhp?
5 sounds about right though.
-Todd
SN95 Director
i'd put a 10 spot on it that you'd gain more power with a lid, ported TB or Pulley then you would with a stock replacement Y. the Y may be flat but it flows the same volume as the non flat passenger side.
Originally Posted by jrp
like i said before, dont bother ******* with the stock Y. any money invested toward a stock manifold setup will be lost when in inevitably (sp) switch to LT's or Mids.
I got seven more horses with this y-pipe. It is a custom y-pipe with a magnaflow true
y-merge collector. Do a little search with in the site and I belive you will find people getting decent gains with people using a setup like this. Some I have seen use the flowmaster merge collector. here is a pic
thanks for the info guys. i never knew that the flatten y-pipe is just as good.
