Exhaust fume smell
Exhaust fume smell
Whenever my car is not moving, the inside smells like exhaust. This, after installing headers, cam and off-road y-pipe. The exhaust is not leaking anywhere as far as I can tell, so I am assuming that not having cats is the reason for the smell. Would getting a y-pipe with cats eliminate the smell of exhaust? If cats are not the problem, what could it be? After driving for a while, it really makes me feel sick, so it can't be good.
Yes, it was tuned. It was a lot worse before it was tuned, it would actually puff blue smoke when idling. I am running the TR230/224 cam, if that matters.
Common problem with running !cats with a cam. The only way to fix it, or help at least, is to put cats back on there. There is no way to tell with your nose if it is running rich or lean. You have to have a wide band O2
I'm not running O2 sims, I had the rear O2s deleted and I am only running the front O2s. I was thinking of getting the random tech y-pipe, or something similar, as I am not too crazy about spending $800 for something like that. There was some other guy saying that this particular cam causes this strong exhaust fume smell...and if it is a choice between $800 for a decent cat y-pipe or $400 for a different cam, I think I'd rather go with the cam.
1 Post
It does not blow smoke anymore, the tune seems to have fixed that. It does still make visible exhaust smoke on cold starts, but once the engine heats up there is no visible smoke while idling.
Originally Posted by DaddySS
Well yes, except if it is running pig rich and spewing poorly combusted exhaust you will have have more fumes.
Exactly the opposite if your running lean, there is no way of telling
