Have I run out of external mods? What to do next if not?
The list below is what Ive mostly done to the car. It think it has everything, but I may have left a few things out. Anyhow, I was just wondering if Ive completed all the bolt-on modifications and its time to move to the internal section or if there's something that Im missing? I want to hit 10s naturally aspirated with a cam only and I wanna make sure that I have everything else that will help me to get there. Anyhow, just let me know. Thanks.
2000 Camaro SS
Fast Toys ram air kit
K&N air filter
Texas Speed & Performance air lid
Granatelli MAF
SLP high flow bellow
Bauer Racing ported & polished throttle body
LS6 intake manifold
NGK TR-55s
Holley 9mm wires
Kooks 1 3/4" long tube headers
Custom 3" true duals w/Dynomax bullets dumped
ASP underdrive crank pulley
Meziere electric water pump
MTI C2 cam (224/.581/112) plan on changing cams, but dont know which one
Manley valvetrain kit
AMW oil catch can
Billingsley ABS delete
Century 200-4R w/all options
Yank SS4000 soon to swap over to a PT4400
TCI flexplate
Hal shocks in a 4 corners w/R series in front
Spohn-LCAs, PHB, TA, SFCs, & 25mm rear sway bar all in chromoly
BMR-K-member, upper & lower a-arms, & relocation brackets
Airlift airbag
Prothane motor mounts
Energy Suspension transmission mount
Denny's nitrous ready driveshaft
Strange 12 bolt w/4.10
Bogarts-15x10/ET Drags 15x4/165R
Wolfe chromoly 6 point weld-in roll bar
Hawker battery
Kirkey Pro Drag racing seat
2000 Camaro SS
K&N air filter
Granatelli MAF
LS6 intake manifold
NGK TR-55s
Holley 9mm wires
AMW oil catch can
TCI flexplate
Airlift airbag
Hawker battery
Strahley: I havent ran it yet, not with my new set up anyway. I plan to do so after the gears are broken in. I also need a set of tires because mine are gone.
robertbartsch: I could never sell my car...have way too much invested to let it go now. Chevys only for me.
Keenov: I have done some weight reduction, but I dont want it to be completely stripped. Ill have to weigh it next time Im at the track.
Im shooting for 10s naturally aspirated cam only, so nitrous is out of the question. I building my car mainly for the drag strip, so I dont run a front sway bar. The STB doesnt do anything for straight line racing and is added weight, so dont run one.
00Z-28Maro: I removed the power steering, so I had to get a shorter belt, does that apply to the short belt mod? The only things that the belt goes around is the alternator, crank, tension pulley and under the water pump.
SMOKIN01TA: I have a Hawker battery, I forgot to mention that in my list, Ill add it in there. Will I need a 90mm intake and throttle body with the cam that I have now or are you saying I will need it for the bigger cam?
90mm will benefit you now and even more with the bigger cam.
I thought about changing intakes and throttle bodies, but now the LS2 comes into play and makes it hard for me to decide. Also, I read somewhere that they are going to make a C6 ZO6 with an LS7 in which that particular intake will be available soon. Not sure if I should wait and see what happens, or buy the FAST products. They sure are expensive and I think I remember reading that there wasnt much difference between the LSX and the LS2.
nobody has dyno'd the LSX and LS2 back to back, so nobody can say. they both have 90mm tb's, so its tough to tell if they're both gaining everything just from that. i'm willin to bet the farm that the lsx will edge out the ls2 every time tho with a big cam b/c of improved flow design, especially when port matched.
-Todd
