Question for you 90mm users L@@K
Originally Posted by Another_User
I was wondering when somebody would ask that. I never could understand why FAST made a 90mm throttle body when there was no MAF in existence that could feed it.
Originally Posted by Beast96Z
Actually, Pro-M makes one for our cars that is 90mm, but it is over $400, so you don't hear much about it. There really pretty cool because they actually take into acount what you have done to your car so they are better suited for tuning.
Originally Posted by Chris ARE 385
You could tune the MAF out of the equation and use a solid 4 inch tube in its place.
Originally Posted by NoseUpChromeDown
I second on that one. Wouldn't that be somewhat of a dissadvantage though? Isn't there good reason we use MAF sensors? More precise? (while not attempting to hyjack this thread...)
Originally Posted by JF WS6
Who is or can do speed density tuning in the states? That would be awesome to just ditch the MAF.
Originally Posted by SpeedDemon
Speed Density is actually a better way to tune (arguably) than MAF tuning. The problem is, SD is more difficult and does not have the ability to adjust for minor mods like MAF's do. Response time should be a little faster as well.
Could we not just incorporate the electronics between two 4" pieces of pipe? Isn't there a way to adjust the sensetivity of the MAF for such an application? It'd be like using an 85mm MAF on a V-6 I guess. Doable? Could this cause improper metering? Perhaps screening would make something of that size more precise...?
Originally Posted by BADZ
85mm will hold over 600hp's N/A so it will be fine. What would you do on a 105mm TB?
Hmmm...this will be post 1000 for me...I wonder if that thing under my username will change...
Moderator
What did you have to do to make it work (rid of the maf) LOnSLO? Megga tuning or what?
Originally Posted by LOnSLO
Well, you could always ditch the MAF altogether. That's what I ended up doing.
I would not want the headache of have to re-tune it all the time w/o the maf, I think I will just run it for now and later figure out something else...
There is no re-tune all the time. The trims update as normal. I finished my VE table, it runs perfect. I fixed my part throttle cruise bucking, now I need to eliminate closed throttle deceleration surging (minor), and bucking part throttle coming off the line slowly (like in traffic). The cruise bucking was all throttle cracker once I pulled that MAF out (+ .9 to the entire table). I suspect my bucking off the line to be the same.
