LS6 intake Done!!
LS6 intake Done!!
ok so i just finished and started it up just as it was beginning to rain, i didnt use the ls6 coolant lines (so for anyone that cant find the lines this is a good alternative) just grinded the chekerboard on the bottom. car idles great and pulls so much harder after 3000! the only problem i have now is...... TRACTION!!!!1!!1!11ONEONEONE
well if i was to do it again i would just cut them all off because i found myself grinding then test fitting then grinding some more then fitting again.... ect... also cut out the green clips that hook the knock sensor wires to the coolant lines
