TD's with XR-1's ?
TD's with XR-1's ?
I've heard vid clips of people with true duals and i've seen pics of over the axle TD's. but i have two questions
1) Is it possible to have TD's with two XR-1's over the axle?
2) if it's not than will you be able to see the two mufflers before the axle with turn downs?
My car is not lowered..suspension is still stock. Thanks
1 Post
I had TDs w/ Borla XR-1s dumped at the axle. The mufflers are visible, just like all other mufflers that are dumped. Ground clearance was ok, but not the best. I have a sound clip in my sig.
SSOnYourSix also has Borla XR-1s dumped, but he did the floorboard mod, and tucked the mufflers up nicely.
remove floor board? wow. the reason i ask if they're visible is because i know that on a camaro, the muffler is totally visible, but with the ws6's, it's a lil more covered than a camaro. thanks a lot for ur info.
1 Post
What's your email, I can send you some pictures of the Borlas from behind on my Camaro.
Originally Posted by Z28Venom
Nah, it's not removing the floorboard. It just hammering or pressing the floorboard up to gain some clearance.
I have the same mufflers and I need to gain some clearance. Will the back seats still be usable?
thanks.
1 Post
Originally Posted by bbz
send me some pics. my63nova@houston.rr.com
thanks.
thanks.
Check the webshots in my sig. I added some pictures of mine. I'm also adding the two that I have of SSonYourSix's setup.
