How about this exhaust setup for a blower
Old 10-09-2004, 12:53 PM
MstgKillr's Avatar
Default How about this exhaust setup for a blower
How good would this setup be, sound and power for a blower.
Kooks 1 7/8 race headers
Dynomax bullit mufflers off of the header collectors one on each side
Kooks off road y-pipe with the reducer cut off for a true 3 in pipe
Magnaflow catback exhaust with the reducer cut off for a true 3 in pipe
I would just run cats but I want to use Harlan's two step and I have already taken off the air pump.
Think this will sound ok, no rasp
Old 10-09-2004, 09:50 PM
cyphur's Avatar
pretty much any time you run a catback w/o cats, and long tubes, it can sound shitty. the exception being GMMG or a custom sweet thunder chambered exhaust. only cuz they're the same mufflers used on true dual exhausts. i say just run true duals if you're not gonna run cats. why mess around with a y-pipe and catback?
Old 10-09-2004, 10:01 PM
MstgKillr's Avatar
I have thought about a true dual exhaust but I have a Trans Am and with no exhaust tips it looks kinda funny. I don't see that many people with an over the axle setup. To make things worse I will be using a spohn tunnel mount torque arm.
Old 10-09-2004, 10:23 PM
cyphur's Avatar
Check my sig.....I'll be runnin true duals dumped before the axle.
Old 10-09-2004, 10:43 PM
Z28Venom's Avatar
Your setup should sound pretty good. The bullets right off of the header should definitely help to kill any rasp that would have been there without them.
IMO is should sound pretty damn good.
Old 10-09-2004, 11:37 PM
cyphur's Avatar
missed the part where you had the bullit mufflers right off the headers. that should help. i need to learn how to read better
Old 10-10-2004, 02:34 AM
mnc2886's Avatar
If a cop tries to get you, I bet you can pass the bullets off for cats. Not too bad of an idea.
