Need help with injectors.
Old 10-10-2004, 01:50 PM
98Blubrd's Avatar
Default Need help with injectors.
Is there any good write ups to swap injectors? I know it should be pretty easy i just dont feel like fiddling around in there til i get some info. thanks.
Old 10-10-2004, 01:54 PM
Z28Venom's Avatar
Pretty simple.
When I did it:
Fuel line disconnect tool.
Remove either 4-6 fuel rail bolts.
Lift up rails, some injectors will remain on the fuel rail and some will remain stuck in the intake. ( Just wiggle them all out.)
Install new injectors and reverse the process.
I hope you have Edit or HPTuners if you're going with bigger injectors.
Old 10-10-2004, 02:42 PM
98Blubrd's Avatar
whats the fuel line disconnect tool look like? is it necessary or will something else work. where does it attach to? do you have to take both fuel rail sides off at the same time. it looks like there connected. thanks.
