True dual setup with one muffler.
Old 10-14-2004, 02:35 AM
al
al's Avatar
Default True dual setup with one muffler.
I`m going to run a true dual setup over the axel very soon and want to keep a stock look from the rear of my Z. I saw that Magnaflow has a dual/dual muffler that has 2 inlets and 2 outlets that has a straight through X pipe built in. Are there any companys that make a dual/dual straight through muffler without the X pipe that will look stock on my car. Keep in mind I want to look stock but not sacrafice performance. I may just keep the 2 bullet mufflers on the H-pipe but I have had the Troopers pull me over with my cut out with stock exhaust and cats. Thanks for any help.
Old 10-14-2004, 04:10 AM
2MuchRiceMakesMeSick's Avatar
I think anything but a race muffler will not yeild as good of a flow. It would be a waste of money to run true duals into a catback exaust. You could still run true duals over the axle with two race mufflers and have your stock tips welded on. If I wanted to look stock that is what I would do.
Old 10-14-2004, 10:58 AM
ls1_doc's Avatar
Agreed, any stock looking tips will look stock but anyone will know by the sound that it is not a stock exaust
Old 10-14-2004, 05:23 PM
lsx24's Avatar
The reason stock DOHC mustangs sound good is they have room for actual mufflers. If you want a true refined dual sound definitely buy a Mustang.
Old 10-14-2004, 05:58 PM
ls1_doc's Avatar
actually alot of the sound difference is because of the cylinder firing order versus other cars. The mufflers help but not all the reason
Old 10-14-2004, 07:29 PM
lsx24's Avatar
Mustangs got True Duals from the factory, but I thought cylinder firing order was the same for both V8s.
Old 10-15-2004, 12:54 AM
al
al's Avatar
I`m not going to run it into a cat back exhaust. The muffler has a straight through X made in it. Alot of us run a X pipe and call it true duals so what I was woundering if using this muffler would be any diffrent than a X pipe. It`s straight through and has two inlets on each side in the back and then two outlets in the front that meet inside the muffler just like a X pipe would. I agree about the two mufflers though. I might end up just running two mufflers and say to hell with the stock look. If I can`t get any good replies thats what I`ll probably end up doing. Thanks for all the replies so far
Old 10-15-2004, 03:16 AM
Did he really say that
How about you buy the mustang and ill blow by you while your listening to your exaust
On a serious note, I have yet to hear any mustang sound as good as 3" sweet thunders with an X pipe.
Old 10-15-2004, 09:20 AM
ninobrn99's Avatar
i know what muffler your talking about..p/n:11386. i dont think its a bad idea. this is what your talking about doing right??
Old 10-15-2004, 11:09 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Routing both pipes (2.5" max) over the axle on the passenger side is the way to go.
If the muffler already has an X, you don't need another X-junction. But then again, the muffler's X would be so far downstream that putting the first X may not be a bad idea.
Old 10-15-2004, 12:32 PM
al
al's Avatar
Actually thats the type of muffler I`m looking for. Is that a magnaflow. That is really straight through without the X built in the muffler.
Old 10-15-2004, 12:41 PM
SSilver's Avatar
who says you cannot get two fill size mufflers under an F-body?
I can still go up higher with them so they don;t hang low but i have been too lazy...
Old 10-15-2004, 01:00 PM
777's Avatar
i don't think anyone has actually...haha...he just wanted it to look stock..why? i don't know...it would be more than obvious that it isn't stock when you crank it up or drive by someone
Old 10-15-2004, 01:21 PM
al
al's Avatar
Yea I know it wont sound stock. I have a cut out now and it dosen`t sound stock at all. Why do I want to look stock........I don`t know thats just the way I want my car to look. I found a shop that said they can run my 3 inch H pipe over the axel. They said they have done 3 inch on F-bodies befor. I guess I`ll see when I get there. Everyone says 2.5 inch is the max over the axel.
Old 10-15-2004, 01:27 PM
!LS1 11 Second Club
This diagram has a major flaw.
The exhaust wouldn't cross flow like that. That muffler is meant to be used as 2 in, 2 out on the same side.
Old 10-15-2004, 01:39 PM
djfuzzy's Avatar
Eww...I have never heard a Ford anything sound as good as a GM anything.
Old 10-15-2004, 01:55 PM
blacktransam's Avatar
a little hacking on the hump where the back seats are supposed to go underneath and i hear you can reallt tuck those mufflers... so i've heard...
Old 10-15-2004, 01:58 PM
!LS1 11 Second Club
Here's my setup.
It came off last week due to need for better ground clearance. (low hanging SLP collectors were more to blame than the X-pipe itself)
Old 10-15-2004, 02:38 PM
patSS/00's Avatar
They have the 2 in 2 out either with internal X-over (#11386) or without (#11379). I was looking at it a while back, seems like a possibility would be putting the X muffler in place of the X-pipe if there was enough space underneath, or in back like the diagram and leave out the X pipe altogether.
Old 10-15-2004, 02:48 PM
z98
z98's Avatar
Most magnaflow mufflers are straight through designs than can be flipped for clearance.
Not sure on that particular muffler, though.
