Cars sticks at 2K idle when moving
Old 10-20-2004, 11:16 AM
xfactor_pitbulls's Avatar
Default Cars sticks at 2K idle when moving
As said above. I think it is my throttle body doing it. The guy that had it before me drilled it out for a 112 LSA mine is 114+4, but a pretty high duration 228/232. If I totally epoxy fill the hole, does that sound like it will knock out the problem? Or could it be something else? I am tired of coasting to stoplights with the engine spining like mad. Especially past a cop. Ideas?
Brandon
Old 10-20-2004, 03:29 PM
Brandon
No thoughts gentlemen?
Old 10-20-2004, 04:12 PM
Moderator
jimmyblue's Avatar
If it idles low once stopped but high when rolling,
that is probably some combo of throttle cracker
and idle airflow settings. If it settles down at a
dead stop then there's a chance that just tuning
will fix it.
Old 10-20-2004, 05:19 PM
Shaner's Avatar
Either your blade has been drilled to big for your car or it could be the idle set screw could be set to high. (or a combination of both)
Old 10-20-2004, 06:09 PM
If it were an idle set screw wouldnt that keep the idle high even when stopped? I just thought it had to be the drilled blade since movement translates into air passing through it telling sensors to still shoot fuel. I am going to totally epoxy it up and see it that fixes the problem.
Brandon
