Need Help
Need Help
I recently changed my engine coolant temp sensor, cause i broke when i was doing my header install.Then i put some more coolant in, to compensate for what leaked out. Ran for a while everything was good, then got home turned off the car , later on i went back outside and tried to turn the car on but nothing. Then i noticed a coolant leak in hte front passanger side, but i cant seem to find where its coimg from, checked all the hoses and everything was good, if anybody can help it would be awesome, getting a lil fustrated and just want to drive my z, thanks
1 Post
nah, i wish i did, but im thinking it could be hte sensor, becasue the cars acting the way it was before when the sensor was broke, i dont know if its possible for hte sensor to go bad taht quickly, and the cooland leak was somewhere on the lower part of the passangers side casue it was all wet in the fender welland kinda along where the ac lines are at, i doubt that will help but thats the most i can give you right now , thanks though
1 Post
Did you use a teflon tape when you installed the sensor? What did you use to seal it with?
