A/C condensor problem
Old 10-29-2004, 11:03 AM
sleep-ez's Avatar
Question A/C condensor problem
i have started to hear a noise comming from the A/C condensor. it sounds like a grinding, when i press a pry bar against it, it goes away also when i turn the A/C on it goes away. the A/C works but i dont know what the actual problem is, what is a fix for it please help. i dont know how serious this problem is
Old 10-29-2004, 11:26 AM
Moderator
jimmyblue's Avatar
The condenser is the heat exchanger that sits in
front of the radiator. Do you mean the compressor?
I've never heard a condenser make noise, it just
has gas flowing in one end and liquid out the other.
I have had compressor clutches go bad, it may be
the bearings are just getting crusty or worn. When
the A/C is engaged the compressor clutch no longer
spins on its bearings, it spins along the compressor
shaft on the internal bearings instead.
I believe the compressor clutch can be replaced
separately, but as long as it spins freely I would
just wait. Dunno if there is any lubrication you
can or should do, that wouldn't also mess up the
clutch itself.
Old 10-30-2004, 01:13 PM
sleep-ez's Avatar
it is not the condesor, it is the compressor. i was told that a bearing is going out.
Old 11-06-2004, 05:08 PM
WILWAXU's Avatar
Probably time to look for a rebuilt unit.
