SLP Radiator Porblems?
Just wondering if anyone else had problems with their SLP Radiator leaking? I've been finding coolant under the car from time to time. Not a lot, just a spot here or there. Not enough to be a cooling problem so I've just been tightening the hose clamps & watching it.
But now I have this sludge on my overflow dipstick tube, so I was out trying to figure out what it is, looking at all the levels - oil, tranny fluid, power steering fluid. It smells like it a mix of tranny fluid & coolant. So I pressurized the system to 17lbs with my coolant system checker & unplugged the top tranny cooler line. Sure enough, coolant starts running down the radiator & forming under the car.
But here's the kicker, it's NOT coming from the tranny cooler fitting. It's coming from this black plastic cap just under the tranny cooler fitting. I thought that was for the fluid level sensor my car doesn't use, but there is one on the driver's side too, so maybe it's for an oil cooler upgrade I didn't get. Anyway, I'm thinking if water is leaking out of that, maybe I have a defective radiator & tranny fluid is leaking into the radiator from the tranny cooler section. (since trans line pressure is MUCH higher than coolant pressure)
Anyone ever have or hear of this problem?
