Long Bolt for pulley install is stuck...
I am in the middle of a cam install and the long bolt to put the pulley on is stuck (wont untighten or tighten). This is a stock pulley and it as never hammerd in by anything. It got torqued down with a 1/2 impact and then it got stuck. I have searched but have not really found the answer to this. I have been told it is more than likely the inside of the crank threads got stripped or the bolt itself got stripped?
I was told by a shop that they would have to pull the motor out and replace the crank if it was stripped!!
Has anyone else had this problem??
Originally Posted by conan
Were you puting the pully back on? When i did my cam swap I bought the longer arp bolt Because i was told the stock bolt was not long enough to get the threds started. "wich was true" .
