LS6 intake Manifold From ZO6 to C5
Hey guys, i recently purchased a used ls6 intake manifold that came off of a ZO6 Vette. It's going to be installed on a 99 C5, my question is do i have to change anything for the install..... for example coolant pipe etc. any help would be greatly appreciated. Thanks in advance.....
Yes you will need the coolant cross over pipe and the 2 block off plates for the heads so the intake will bolt on. I'm not home right now so I can not give you thye part#'s....they did change the parts numbers to an updated number!!! Use the search feature above this my help.
Later
tim
Later
tim
