LS6 intake & nice gains
Old 11-27-2004, 05:38 PM
11 Second Truck Club
LS1BirdDRG's Avatar
Default LS6 intake & nice gains
Went to the track to get some hard numbers after my LS6 intake swap. All I can say is anyone running a cam with the stock LS1 intake should strongly consider ditching it. I also installed a March pulley at the same time but I'm sure the majority of my gains were from the intake.
My previous best trap speed was 113.5mph and last night I ran 2 different 116mph plus runs on bad driving. (116.36) One run I banged off the limiter in 1st gear pretty bad and the 2nd run bogged it outta the hole. I shoulda broke 117.
This is a totally different car now, I must say I'm very pleased. I think I may be close to the 400rwhp mark.
Old 11-27-2004, 06:08 PM
tomaSS's Avatar
Nice! Did you tune it at all after the intake swap? I will be installing an LS6 intake when I do my cam install.
Old 11-27-2004, 06:11 PM
M6HuggerSS's Avatar
what were your dyno numbers before the swap? is it tuned yet?
Old 11-27-2004, 06:43 PM
LS1BirdDRG's Avatar
I had it tuned over the summer at MTI after I installed the cam. It made 382hp and 377tq back then. Jayson deleted my egr and such for when I installed the intake. He said tuning would not be necessary if I just swapped the intake. He was right I would say!
Thanks, I don't wanna take any credit away from the pulley either. It's a nice piece, I wish I knew how much of the gain was from it. I was only expecting maybe 3-5rw at the most from the pulley.
tomaSS, good luck on the cam swap. You'll be happy.
Old 11-29-2004, 09:25 PM
M6HuggerSS's Avatar
awsome numbers.......btw
Old 11-29-2004, 10:57 PM
Keenov's Avatar
How was the weather for both runs? Since it was different days, you could have actually gained more.
Old 11-30-2004, 01:52 AM
amit's Avatar
awesome!!!
my next mod is the ls6 intake and pulley..
Old 11-30-2004, 10:33 AM
LS1BirdDRG's Avatar
Thanks fellas, the weather was better last weekend. One of the local guys said the DA was in the 300s. The weather wasn't bad when I ran before, but definately not as good as last week. It's my own fault I didn't break 117mph due to driving. I also need to do the master drill mod and rebleed my clutch. That will help the shifting.
Old 11-30-2004, 10:38 AM
98Z28MrO's Avatar
Ls1bridDRG, what did your e/t end up being? I have been looking at the cam for a while and have the ls6 intake stock and was wondering what someone with similar mods was running with it.
Old 11-30-2004, 10:58 AM
LS1BirdDRG's Avatar
Well, this is how bad it was. I ran my best time on a missed shift. 12.4 @ 112. Also had traction probs on other runs. (12.5 @ 116, 12.6 @ 116)
I should have done better.. I need suspension too.
Thing is, all the runs had different problems of some sort. There's always nexttime. You'll like the cam, very good manners.
Old 11-30-2004, 03:15 PM
cablebandit's Avatar
been proven for years. You will definitely feel it pull harder up top. A very good mod and easy to install.
Old 11-30-2004, 04:05 PM
SRfastZ's Avatar
what kind of LS6 intake did u get ?>????????????
Old 11-30-2004, 09:17 PM
LS1BirdDRG's Avatar
I can look at the part number tomorrow, I remember it was alittle different than others. It's a different # than my wife's 02 SS. (I looked)
I always thought the LS6's were the same anyway. It did come off a Vette because I had to install the linkage inserts for the throttle, but otherwise to my knowledge the same.
Old 11-30-2004, 09:26 PM
glennster's Avatar
Not flaming you but I have done 2 LS6 intake swaps,one being my car and the ET/MPH gains were negligible.My car usually runs high 113-low 114 but if I bog I damn near get 116.Maybe your car was held back by the LS1 intake but I think your test was flawed.
Old 11-30-2004, 09:36 PM
Racehead's Avatar
That's an unexpected type of gain ?? Glad it's worked out so well for you
Old 11-30-2004, 09:54 PM
LS1BirdDRG's Avatar
All I can say is the Butt dyno felt it and the numbers on the slips showed it. I don't see how it's so unbelievable for a cammed car to gain 20+ hp with the intake swap and a few more on that with the pulley.
But yes, thanks, and I'm happy.
Old 11-30-2004, 09:57 PM
Ferocity02's Avatar
Looks like I need an LS6 intake!
Old 11-30-2004, 10:17 PM
SRfastZ's Avatar
would a FAST 90mm intake be better ?
Old 11-30-2004, 10:32 PM
Racehead's Avatar
Yes it would be better. For the $1300 it would cost you to put one on I'm not sure the extra 10 hp would be better enough though ?? Depends on your wallet and goals of course
Old 11-30-2004, 10:35 PM
SRfastZ's Avatar
does that $1300 include the throttle body too ???
