Installed ASP Underdrive Pulley
Finally installed my ASP underdrive pulley today, and I have to say using all the tips I learned on here made the install go much easier.
I followed the general instructions from here.
I also used the all thread bolt from Code4
This helped out greatly since it was much safer and also allowed the puller to completely pull the pulley off due to it's extra length.
Put the pulley in front of a space heater for about 10 min and it slid right on.
All told it took about an hour and a half to do the whole install, but I also had the car up on a ramp. That made it a lot easier except for when the ratchet wrench slipped off the pulley puller and I punched myself with a glancing blow. Had to take a half hour time out to ice it down so I didn't get a black eye
Where did you purchase you ASP setup? Also do they have a website? Another thing, it seems like your pretty happy with your setup, did you see a noticible difference in power after you installed it? Just curious about it...Im getting this setup for Christmas. Joel
2001 Camaro SS, t-tops, M6, the works, several boltons
Originally Posted by D Rock
So what is the bolt pictured used for?
ssmaro,
I purchased the whole ASP setup excluding the all thread rod assembly from here http://www.tbyrne.com/ls1catalog.html
It included the necessary belts and new crank bolt.
I bought the all thread rod, nut, and washers from a forum member named code4.
I could instantly tell a difference in low speed driving. There was noticably less effort to get the car moving, as in slipping the clutch or reving the engine. I can't feel a huge hp gain, but I can feel the reduced load on the engine due to the slowing of the accesories and lighter pulley. An underdrive pulley nets anywhere from 5-10rwhp on average.
That's what she said...
ssmaro,
I ordered my all thread bolt from Code4 today. Seems like a great idea and I don't want to deal with going to the store and trying to find the same bolt as the stock one but longer, etc... Pain in the ars if you ask me. I'd rather just buy his since he was smart enough to come up with the idea.
