what bellow for TPIS 90mm and stock MAF
Old 12-07-2004, 03:05 PM
Kurtomac's Avatar
Default what bellow for TPIS 90mm and stock MAF
what bellow are you 90mm guys runnin with your stock maf....i have the raised WS6 airbox if it matters
Old 12-07-2004, 03:16 PM
Kurtomac's Avatar
also what are you guys doing with the PCV tube out of the valve cover?
are there coolant lines that go in/out of this tpis tbody?
Old 12-07-2004, 03:42 PM
smokin' joe 00 ss's Avatar
No there isn't any coolant lines on the TPIS T/B. I'm running 85mm maf so I can't help on the bellows for a stock maf.
Old 12-08-2004, 08:21 AM
Kurtomac's Avatar
ls6 intake coolant lines are fine arent they?
Old 12-08-2004, 09:50 AM
Yes they are, I'll see if I can get Dark Age to post a couple of pic's for me of my fresh air tube & Small K&N filter on the pass. side valve cover so you have a Idea of what I did with mine.
Old 12-08-2004, 09:53 AM
LSUxBlake's Avatar
Or you could just go into the bellow for fresh air. That's what I'm doing.
Old 12-08-2004, 09:56 AM
DanZ28's Avatar
I'm curious as well. How are people attatching their air lid to an 85mm MAF and then to the 90mm TB??
Dan
Old 12-08-2004, 10:32 AM
LawmanSS's Avatar
Dan
My SLP 85mm MAF came with a small piece of silicone hose to attach to the lid.
I've heard of someone stretching their SLP bellows to fit the 90mm, but I just bought this one:
http://shop.airflowonline.com/Mercha...tegory_Code=HH
Old 12-08-2004, 11:18 AM
Kurtomac's Avatar
smokin joe im still torn on either running a breather off the valve cover or running a tube into my bellow which i dont really like the idea of doing....we'll see....fireball had a good point with the unmetered air into the motor by doing a breather....maybe ill call TSP and see what they have to say
Old 12-08-2004, 11:19 AM
Kurtomac's Avatar
oh yea pics would be awesome smokinjoe
Old 12-08-2004, 11:20 AM
DARK AGE 53's Avatar
Here's the pics Joe wanted me to post.
Old 12-08-2004, 11:34 AM
Kurtomac's Avatar
sweet thanks,...how did he connect that breather on the little nipple on the valve cover? and where did he get that k&n breather that setup looks sweet, is he using a AMW catchcan....i still need to do somethin like that
Old 12-08-2004, 02:59 PM
Ok as for the unmetered air when I took it in to get it tuned they said the ECM was having a little problem with the unmetered air coming in but it would learn it and adjust for it real quick which it did. As for the breather I used a small piece of 3/8" hose at the valve cover which connect's to a small blue fuel line elbow(bought at a local speed shop) and used another piece of small hose off the elbow to the small breather(bought at a local speed shop). Yes that is a AMW (oil accumulator) catch can with Dark Age's bracket. Oh thank's Al (Dark Age) for posting the pic's for me.
Old 12-08-2004, 05:50 PM
Glad to help Joe.
