QTP headers installed with sound clip
I finshed my QTP this past weekend, the header only took 1 1/2 to put in, but the y-pipe was hard cause it came in 5 peices and we couldnt get the y-pipe to fit up there nice so it hangs low so my clearance is about the size of a soda can. I have a sound clip video on ls1sounds its the first one 02 SS QTP's w/magnaflow
thanks to Chad from ls1sounds for the video, here is the direct link http://www.ls1sounds.com/magnaflow/...SS_titus-ss.wmv
or http://ls1sounds.com/magnaflow.htm and its the first one 02 SS
!LS1 11 Second Club
I had the same install as you did. Very easy LT install/ Bleeding knuckles Y-pipe install. I ended up takeing the Y-pipe to an exhaust shop after I got fed up. Should have driven the car w/ open headers to the shop from the get go and saved me hours of frustration.
the interior noise is not that bad cause you can control the rpm with a six speed, i had lt's w/ ORY and magnaflow on my 94 Z28 A4 and the sound drove me crazy inside the car
