CME tip drop 5- 10 cooooooooome iiiiiiiiiiiiiiiinn
A shop told some one in this forum that adding CME tipe will cause a drop of approx. 5-10 HP on the dyno....how true is that? he said that its like adding a second y pipe
I don't believe that in the least bit. Look at the C5 exhaust, it has just as many bends as the CME exhaust does. It is the same diameter as the tailpipes and it has no other restrictions other than the added bends so I don't believe it. I wouldn't care if it would, I'm still planning on adding it to my exhaust, it just looks too good. They would have to show me on the dyno!
A drop in hp seems reasonable. I mean, think about it, airflow has gotta slow down with a bend like that. Think about how much water slows down at sharp bends. I wouldn't doubt a decr. in hp, but I think it will be neglible...don't worry about it. Or just add a cutout to the I pipe to negate the drop in hp.
I have firsthand info on this subject. I have replaced my factory Dual Dual muffler with a Corsa muffler and retained the 2.5" piping and CME tips and valance. I also have a 3" QTEC in the I pipe before it bends over the axle. During my last tuning runs at Rapid I did a closed vs open cutout comparison. My 3" cutout only gained me 4rwhp @ 5rwtq over the Corsa muffler and CME tips. These gains were only from 3500rpms and up. Anything below 3500rpms the lines were identical. FYI
Originally Posted by WS6FirebirdTA00
just dont get the quad tips, ive seen some in person and they look even worse than they do on here (well at least the cars that i saw it on)
This would be an interesting side by side dyno comparison. I'm willing to bet a loss in peak hp with similar tq numbers after swapping on CME. Just use your heads guys, more bends equal more decreases in airflow which equal less power.
I don't understand why there is a question on this. A difference in power is a difference in power, no matter how minute or insignificant.
