Shift Light Question.
Old 12-19-2004, 02:41 PM
al
al's Avatar
Default Shift Light Question.
I just had a cam installed last week and got my rev limiter bumped up to 6900 this week when I got my tune. Well I took my brother for a ride in it today and I hit the rev limeter when the tac was reading 6500. I know that the stock tacks are off so it`s time for a shift light. What brand and model number shift lights are you guys using. I`m not going to get a tac so I need to know some shift lights that will work with out the tac. Also how hard are they to install?
Thanks for any help,
Al
Old 12-19-2004, 03:22 PM
glennhl's Avatar
I used a Harlan and I like it alot. It's easy to install (go to www.installuniversity.com). I put mine in the center A/C vent and I see it fine. Most people will tell you to get the red led's. They are the easiest on your eyes at night. I also set mine to 6300 rpm with a 6650 rev limiter and if I'm not on top of it, I can still high my rev limiter in first gear.
Old 12-19-2004, 03:25 PM
LS1TECH Sponsor
badpewter-z's Avatar
i have a raptor and love it havent hit the limiter since unless tires are spinning then it just jumps alot faster to redline
very easy to put in, power ,ground, and 1 wire to the pcm
Old 12-19-2004, 03:52 PM
al
al's Avatar
I`ll check out installuniversity.
Old 12-19-2004, 05:03 PM
Flawless02SS's Avatar
Another vote for the Harlan. Very easy to install and fairly cheap. $30 cheaper than the raptor. I went with the red LEDs and I put it my AC vent
Old 12-19-2004, 05:10 PM
sickss228's Avatar
I have the Raptor shift light, extremely easy to install, and you dont have to wait for a Harlan, because he builds them himself. Both are high quality products and you will be satisfied with either one.
Old 12-19-2004, 05:37 PM
LS1Maniac's Avatar
I went with Raptor because I didn't feel like waiting 2 months to get a Harlan.
Old 12-19-2004, 05:52 PM
al
al's Avatar
Were can I finde these shift lights at. I was looking at one that LG Motorsports that has 7 lights that each one turns on the closer you get to your selected RPM setting. I want to check out the Raptor and the Harlan first though. Why dose it take so long for the Harlan to come in? Someone said he has to make them after you order it or somthing.
Old 12-19-2004, 05:58 PM
LS1Maniac's Avatar
http://www.raptorperformance.com/
Old 12-19-2004, 06:22 PM
joshp14's Avatar
http://www.ws6store.com sells em too.
Old 12-19-2004, 07:22 PM
al
al's Avatar
OK Thanks Fellas.
Old 12-19-2004, 07:43 PM
Durien's Avatar
i got the autometer pro
its either shift or go blind.
Old 12-19-2004, 08:22 PM
al
al's Avatar
How did you mount it. Did you just drill holes in the A/C duct. Did you mount it straight twards the rear of the car or did you anlge it twards you. Also is it easy to see.
Old 12-19-2004, 08:32 PM
al
al's Avatar
So yur saying it lights up bright. Is it easy to install and is it small enough to hide in the A/C vent
Old 12-19-2004, 10:19 PM
Dope's Avatar
Get a raptor with blue bulbs. They're around $100 and are very small and easy to configure. The blue bulbs are the brightest. I have it in my center vent.
Dope
Old 12-19-2004, 10:34 PM
al
al's Avatar
OK so you like the blue light. Do you have the light pointing twards you or twards the rear of the car?
Old 12-20-2004, 08:10 AM
y2khawk's Avatar
link is in my sig
couple days to ship right now
Old 12-20-2004, 08:58 AM
ROJO99's Avatar
Raptor .
Old 12-20-2004, 10:48 AM
LS1TECH Sponsor
Steve Burger's Avatar
Harlan in the center AC vent. It has worked great for 4 years now.
Old 12-20-2004, 01:23 PM
SmokinWS6's Avatar
I have the Harlan, got it 4-5 years ago when he started making them. Only took a week to get it back then. Mines mounted to the steering column just like the old days....
