Oil pan pickup tube distance from base of pan?
Old 12-23-2004, 02:55 PM
GTS346's Avatar
Default Oil pan pickup tube distance from base of pan?
Does anyone know if the engines oil pickup tube needs to be a certain distance away from the bottom of the oil pan?
Are truck and F-body pickup tubes the same or different?
Old 12-23-2004, 04:35 PM
Beast96Z's Avatar
The oil pans are diffrent so I would assume the pick up tube is diffrent. I didn't get an exact measurment when I installed mine, but it was close to the bottom of the pan.
Old 12-23-2004, 09:06 PM
John_D.'s Avatar
It needs to be close to keep it from being uncovered while cornering, or accelerating or braking.
I moved mine to within 1/4" of the bottom of the pan, and was advised to move it back. The reason that I was told, is the hot oil will vaporize from the vacuum produced with the small gap, then condense to liquid form again in the pump, causing chatter and other problems...
I think it was around 9/16" stock, and I ended up with it at around 7/16".
Old 12-24-2004, 12:44 AM
GTS346's Avatar
So general rule of thumb of around 1/2" from base of pan will be safe to use?
Happy Xmas dudes
Quick Reply: Oil pan pickup tube distance from base of pan?
