Intake Manifold : Vacuum Outlet Location
Old 12-24-2004, 04:26 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Intake Manifold : Vacuum Outlet Location
How important is the location of an outlet to measure/accure vacuum off of the intake manifold; say the front verses the rear? I am thinking of using the port for the PCV system to install a boost gauge. Will this give the same measurement as tapping into the brake booster line?
Thanks,
Keith
Old 12-24-2004, 12:33 PM
stevieturbo's Avatar
Yes. But make sure you either restrict the line, or use very small diam hose. Otherwise you will get fluctuating readings/shaky needle
This applies regardless of where you take the reading from on the inlet manifold.
Old 12-27-2004, 08:14 AM
ls1290's Avatar
How size of a hose line would be good? I was thinking of using -4an telfon line to go from the PCV port to the rear of the manifold; I guess that is about 18".
Keith
Old 12-27-2004, 09:36 AM
A hole about 0.010" to 0.020" would be small enough to ensure a smooth reading with no irregular needle shaking.
Simple rubber hose would do. 3/16" or about 3-4mm ID. Depends on size of fittings you are pushing the pipe onto.
