Driver Side header wont come off (hooker long tubes)
im doing my heads and cam awap and cant get my driver side header off. Anythign specail i have to take off to get it off???? I did pace setters on my frineds Ta and then went on and off so easy....anything im missing?????
take off that little bolt right next to your oil filter. it will pull this lip off so you can slide the header right out. sorry i dont know exactly what it is but you must haave taken it off to install them as well. what heads and cam r u going with
youll lose some oil when doing this but when you finished just cap it off and put more oil in. what kind of reply is "did you unbolt it from the y???"
SN95 Director
Originally Posted by jrp
you do know your not removing the header, just unbolting it off the head so it hangs in the engine bay.
SN95 Director
Originally Posted by 1984camaroz28
when u let them hang u cant get the 3rd head bolt on the bottom..... plus i wana take them off and set them to jet hot because the guy befor me was cheap and dident get coated headers
how how do you have the car?
the front of the car is jacked up about a foot ..... the header will only move so far i can barley get on the head bolt but not enought to get it off with out rounding the top of it.....
To get them out, you are also going to have to unbolt the steering linkage. Atleast that's what I had to do with my Hookers. Also, be sure the steering wheel is locked and that you do not move it while the linkage is off. It's a PITA to realign back up.
