Prothane Polyurethane Motor Mounts
Old 12-28-2004, 11:27 PM
Cstick's Avatar
Default Prothane Polyurethane Motor Mounts
My ORY is hitting under the car and I do not want to give up any more ground clearance by adjusting it (I can still go over speed bumps). I was wondering if anyone has used the poly motor mounts and had luck with them. Do you think they will help? I have about 1.5" between the Y pipe and the car, it only hits in 1st, 2nd if it grabs some traction. Also any write ups on installing them. I have not payed attention to them while I have been under the car. Thanks
Old 12-29-2004, 01:19 AM
KALEL's Avatar
they should help with the banging. do a search for prothane motor mounts and look around. there is a write up in one of the threads
Old 12-29-2004, 01:45 AM
WhiteRhino's Avatar
They should stop all the banging.I just replaced mine and posted in Kalel post about "mounts" how i did it.
Old 12-29-2004, 09:45 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have them, and they will help reduce the motor from moving as much.
Old 12-29-2004, 10:08 AM
Dope's Avatar
I only had about 1/2" of clearance and they stopped the banging.
Dope
Old 12-29-2004, 11:35 AM
Z28Venom's Avatar
I would give the Mufflex y-pipe hanger a try first.
Installing motor mounts is a pain.
