Borla Mouth
Old 12-29-2004, 07:39 PM
TAQuickness's Avatar
Default Borla Mouth
Has anyone made a borla mouth with the oval XR-1 (borla p/n 40944)?
If so, can you send me pics of your set up?
Old 12-29-2004, 08:21 PM
ddelallata's Avatar
Getting the BORLA XR-1 #40085 bullet in there is tough enough as it is; my floorboard had to be hammered in a bit to allow the bullet to fit in propperly.
Old 12-29-2004, 08:41 PM
Z28Venom's Avatar
Sorry bud... getting that oval muffler in there would call for too much floor banging.
I've had the Oval XR-1s and they're pretty beefy mufflers. Checkout the webshots in my sig.
Old 12-29-2004, 08:44 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
What's the width/thickness of the oval Borla? I don't remember why now but I thought about going that route 3 years ago , I'm thinking I was going to slip it between the d/s and the floorpan but went with the round Borla instead.
I never did get the round Borla in position where I wanted it, I miscalculated the angles on the pipe cuts and ended up with a fairly low riding muffler (in a BF Hurry when I did it). Luckily, the only time it drags is in extreme road situations or when the car is loaded down.
Could be the oval XR-1 tucks in pretty good sideways? I don't know, but one thing is for sure: almost any modification to to a LM is going to be an improvement as far as irritating rasp goes - at least if you have an A4.
Old 12-29-2004, 08:51 PM
Z28Venom's Avatar
Here are the dimensions of the oval xr-1. Far to big to attempt installing into the i-pipe.
Case Shape - Oval
Case Length (in) - 12.000
Overall Length (in) - 17.000
Thickness (in) - 4.500
Width (in) - 7.850
Old 12-30-2004, 06:50 AM
Case Shape - Oval
Width (in) - 7.850
The 40944 is:
Case Shape - Oval
Case Length (in) - 16.000
Overall Length (in) - 21.000
Width (in) - 7.875
I'm going to give it a shot. I spent a few hours under the car right after I posted this, and I think I can get it in there and have at 0.5" clearance from the body/DS. In this position, I would end up loosing about 0.25" ground clearance.
For ***** and giggles, I slip fit the muffler on while I had her in the air - sounds BAD ***!
Old 12-31-2004, 09:48 AM
I need to post the pics, but just to let you guys know, it works with the oval muffler. It took a little massaging on the LM, but we were able to get the oval muffler in with no loss of ground clearance, and no banging on the body/DS.
Old 12-31-2004, 12:51 PM
MASS seller approved
Time2Kill's Avatar
Would definately like to seem some pics
Old 12-31-2004, 01:34 PM
Thumbs up Borla Mouth Pics
shot from front of car looking back:
shot from front of car looking back zoomed in:
right rear:
left rear:
jet hot Y and DSL clearance (from right side):
muffler to right rear seat clearance 1:
muffler to right rear seat clearance 2:
muffler to right front seat clearance:
rear shot 1:
rear shot 2:
rear shot 3:
Old 12-31-2004, 01:46 PM
Bad Blu Formula's Avatar
I knew it would fit! I should have gone that way before going with the Magnaflow, but I'm happy now anyways.
Old 12-31-2004, 01:56 PM
it took a while to find the right spot for the muffler. I'm guessing the 40085 would have been cake. FWIW, if you are not planning on welding your exhuast together, invest in the band clamps. U bolts are leaking pieces of garbage that will make it next to impossible to get your plumbing seperated.
Old 12-31-2004, 06:08 PM
dug
dug's Avatar
Im surprised you were able to get it to fit. How does it sound?
Old 01-01-2005, 09:36 AM
Originally Posted by dug
How does it sound?
Like a kitten - on crack
I'm working on a video clip right now that will have sound clips of various combos. I'll post it later today or tomorrow.
Old 01-06-2005, 11:09 AM
flyinZ's Avatar
Did ya ever get that video made? Looks pretty good under there.
Old 01-06-2005, 09:30 PM
chris2000ss's Avatar
yea lets see that vid!!!!
Old 01-07-2005, 06:02 AM
((((((Administrator))))))
CRAGER's Avatar
I have the "Borla XR-1 Round Sportsman Racing Mufflers" #40086, part number in Jegs is 157-40086. Its the 3-1/2" round muffler. I was going to get a 3-1/2" cut-out before it but there was no room. Had to bang the floorboards in a little, other than that the round 3" (40085) will fit fine from what I've heard/seen.
It looks like my 3-1/2" fits alot better, no offense:
http://community.webshots.com/photo/...64997310bKkwgf
http://community.webshots.com/photo/...64997289IAwBUM
Peace,
Craig.
Old 01-07-2005, 10:04 PM
LS1 Sounds's Avatar
Looks like it fits in there pretty well to me! Do you mind if I add your pictures to www.ls1sounds.com? I'd also like to host your videos if you wouldn't mind sending them to me.
Old 01-08-2005, 02:17 AM
CRAGER's Avatar
Sure, sounds good to me. Where should I send the vids to?
Peace,
Craig.
Old 01-08-2005, 07:24 AM
Peace,
Craig.
None taken. If you had to bang you floor boards in, then you didn't install it right. The oval fit in with no clearance issues and no banging in anything. The round should have popped right in.
Doenst matter though. Either way they turned out to be a nice sounding exhaust.
Not sure who you were refering to, but I don't mind if you post the pics. I will get some better sound clips. The original ones I took came out like *** from where I had the camera. I should have the video done in a few days. PM me the email address and I'll send it over.
Old 01-08-2005, 10:21 AM
LS1 Sounds's Avatar
You can email them to me at chad@dodds.cc, or if your mail server doesn't like large files you can also use YouSendIt! with the following link: http://www.yousendit.com/?recipient=chad@dodds.cc
Quick Reply: Borla Mouth
