O2 Extenders for Pacesetter LT's
I ordered a set of Pacesetter LT headers for my 01 SS. Will I need the o2 extenders and if so what length ? Looks like they come in 12" or 24". Also which connector will I need on my 01 the flat or square one ?
Thanks !
Thanks !
1 Post
Thanks !
Thanks !
I'm almost certain that you'll need the square connector. Also, when I ordered my Pacesetters from TSP. I purchased 2 - 12" O2 extensions.
If I were you, I would purchase 2002 corvette rear sensors and use those. They have a very long wire that will reach anywhere.
You get a higher wattage sensor and the extended wires!
You "may" spend $20 more, but you get far more for your money.
It's not mine! woo hoo!
Originally Posted by -Q-
Mine came with them, too. I just wanted to buy the extensions with the connectors so I wouldn't have to cut and splice each wire, and I'd be able to take them back off if I ever needed to. Now it's a 5 minute job to revert them back to stock.
same here I'd rathar have the plug & play for a few bucks than screw around with cutting & splicing wires.
I ended up buying (2) 12" extenders from Speed Inc. for around $30 for the pair.
