Help! header install
Old 01-06-2005, 10:19 PM
Bluehawk27's Avatar
Default Help! header install
So everything is back in the car except for the AIR hose that goes into the driverside header. The reason being is that when I put it down to the header, the angel is all off! What can i do to fix this?! thanks
Old 01-06-2005, 10:26 PM
ddelallata's Avatar
angle the AIR tube and fitting. There's no way around it other than deleting the AIR system all together and getting block off plates.
Old 01-06-2005, 10:30 PM
nyg215's Avatar
i had the same problem i bolted the air tube to the header than i pushed it down so it woud fit the air hose
Old 01-06-2005, 10:43 PM
Turo's Avatar
do you have smog testing where you live. if not, just block it off and remove the AIR system
Old 01-06-2005, 10:50 PM
Bluehawk27's Avatar
Yeah i live in cali, I'll try to bolt it down first and then bring the hose over to it. If that doesnt work, i'll try to splice some hose into it.
Old 01-07-2005, 12:23 AM
psykoTA's Avatar
What headers BTW?
Old 01-07-2005, 02:54 AM
Bluehawk27's Avatar
Pacesetters
Old 01-07-2005, 09:26 AM
-Q-
-Q-'s Avatar
I had to do the same thing with my install. Luckily my brother's shop had a pipe bender and we just bent the AIR tube a little more.
Old 01-07-2005, 10:03 AM
MikeG's Avatar
My angle was a little off as well, I just got the bolts started by hand while having a buddy lift up on the AIR hose to straighten it out.
