best 90MM Throttle Bodie
Originally Posted by THRLSKR
Just give LG Motorsports a call and mention the 90MM TB Group Purchase for $469!
I haven't got to work on this as much as I wanted. Hopefully by the end of the weekend I will be done tooling up and programming. Should have the first 6 units done soon for testing.
If you are mechanically inclined, get the FAST and do do the "peen" and "drill" mod to the shaft. I have heard of them fixing one of the 2 problems, but I'm not sure which. FAST will save you some money and there is no core. I've heard the TPIS's have had the same problems as FAST, which in turn you would have to do the same 2 mods, but if you did want to send it back you are dealing with a small localized company instead of a major cooperation. The NW TB's should also be nice pieces and I've never heard of any problem with his C5 TB's.
I am being told the new FAST now have a flat spot machined so the cam does not slip but it still needs pined. I bought mine from TEA along with the 90mm intake so that they could port match it to my heads that I got from them. Price was acceptable and they pined the bearing for me. Good people to work with.
