Can I use 90mm TB with stock LS6 intake?
Old 01-25-2005, 02:22 PM
SDB
SDB's Avatar
Default Can I use 90mm TB with stock LS6 intake?
Searched and didn't find an answer. I have a LS6 intake and ported stock TB. Can I install a 90 mm TB (i.e., TPIS) with teh LS6 intake or do I have to get the 90 mm FAST intake?
What are power gains with FAST 90 mm intake/TB over LS6 intake ported TB?
Old 01-25-2005, 04:59 PM
crow2's Avatar
Hey what's up? You can only run a 90mm TB on a FAST INTAKE or a LS2 INTAKE! Better to use the FAST INTAKE,and you would be good to go.We keep these on the shelf,they go like hot cakes!
GOOD LUCK!
Old 01-25-2005, 08:15 PM
SDB
SDB's Avatar
how much for 90mm FAST and TB?
Old 01-26-2005, 01:03 AM
psykoTA's Avatar
What are the power gains over his LS6/ported TB? is the 90mm setup better suited for a cammed, or heads/cam car?
Old 01-26-2005, 10:28 AM
LSUxBlake's Avatar
Yes, the 90mm is worth 10-25 rwhp on a heads/cam car and will benefit larger displacement motors as well. You don't need it on a bolton/ cam only car. The LS6 intake with ported TB works fine, don't waste your money getting the 78mm LSX, people aren't seeing any gains out of them over the LS6.
Old 01-26-2005, 02:52 PM
psykoTA's Avatar
That was what I was thinking. I want to keep everything matched, and working as a system. So when the cam goes in, it will be LS6/ported TB. Later on when I do the heads I may go with the larger set-up. Thanks for the info.
Old 02-01-2005, 09:48 AM
crow2's Avatar
We have the FST 90MM T/B AND the FAST intake.
The 90mm t/b is $439.95 and the intake is $782.50.
Let us know !!
thanks!
Old 02-01-2005, 10:43 AM
SDB
SDB's Avatar
Let us know !!
thanks!
How much for the optional nitrous burst panels, and all shipped to 46815??
SDB
Old 02-03-2005, 04:06 PM
crow2's Avatar
SDB
Ypu would be looking at a additional $150.00 for the burst panel option (kit) As far as the freight i could estimate this to run you $28.00 give or take! ain't nothing too it!!! Pm me if you decide anything!
Thanks alot!
