AIT sensor
LS1Tech Administrator
Received 1,486 Likes
You mean the intake air temp sensor?
Considering the factory put it before the MAF, I'd guess that's where it needs to be.
Moderator
It's -in- the MAF on the 85mm Delphis, before it on the stock
F-bodies. As long as it's in the air stream proper, probably
doesn't matter much. You'd prefer a location that doesn't let
it heat-soak too much, skewed readings don't help anything.
yea got one of those conical k&ns directly attached to the mass air which follows the bellows to the TB....now to decide to poke it in the end of the filter or in the bellows....thinking bellows cuz its more in a direct flow of air oppossed to the filter...any thing else?
