Normal Idle rpms...M6
Old 02-07-2005, 02:45 PM
98BirdLS1's Avatar
Default Normal Idle rpms...M6
What is the normal idle rpms for a M6 Trans Am.
Mine Idles around 1k, and I think thats a little high, I've checked as much as I can think of and tried adjusting the idle adjustment screw, if I lower it anymore the throttle blade sticks inside the throttle body. My only mod is a lid, and it idle at 1k before the lid. Thanks for any help.
Luke
Old 02-07-2005, 02:59 PM
777's Avatar
that's high...unless you have a fairly large cam (which you don't)...i'd say normal is 750-800
Old 02-07-2005, 03:37 PM
Another_User's Avatar
Perfectly normal. The idle is set at 800 from the factory, and every M6 I have seen runs at "1000", even though the PCM says it is 800. The gauge is wrong. I wish we could calibrate it, because mine is about 200 rpms off all the way up the tach.
Old 02-07-2005, 03:45 PM
8-Pack's Avatar
Mine dosent, check all the ducts that connect to the throttle body. Factory tachs are innaccurate though
Old 02-07-2005, 04:12 PM
BriancWS6's Avatar
Mine shows about 800 when at operating temp.
Old 02-07-2005, 04:58 PM
Well we both have 98s.
Old 02-07-2005, 05:07 PM
Lil Mac's Avatar
Same here.. seems to flutter about 50 RPMS, but not enough to notice.
Old 02-07-2005, 05:19 PM
luv2spd's Avatar
Yeah, they are set at 800 rpm on the stock tune even though the tach indicates 1000. My tach is off by 150-200 rpms all the time.
Old 02-07-2005, 05:31 PM
01_SuperSlow's Avatar
When I was stock, my tach read about 750-800 rpms idle.
Old 02-07-2005, 06:03 PM
I bet it is a 98 thing. They always were the black sheep.
Old 02-07-2005, 06:56 PM
tomaSS's Avatar
My stock 2000 idled between 790-830 rpms. When I got my cam, I raised the idle to 875. I agree, the stock tach is not the most accurate. But mine seems to be pretty close.
Old 02-07-2005, 07:26 PM
jrp
SN95 Director
jrp's Avatar
tach says 1k and EFI says ~750
Old 02-08-2005, 12:51 PM
Camaro99SS's Avatar
800 here I'd bet the that reading is pretty accurate, but once you get on the car or rev it in neutral, the stock tach falls way behind, probably 300rpms low by the end of 1st gear.
Jason
