Just built custom headers, Who has the best coating?
Old 02-07-2005, 06:13 PM
Boosted One's Avatar
Default Just built custom headers, Who has the best coating?
I'm finishing up building a set of headers and I'm looking into the different coatings. What have you guys had good luck with? I want something that looks good as well as holds up.
Thanks
Frank
Old 02-07-2005, 06:23 PM
Sudz's Avatar
Jet Hot of course
Old 02-07-2005, 06:24 PM
anybody have any experiance with HPC?
Old 02-07-2005, 09:18 PM
Flawless02SS's Avatar
JET HOT all the way !!!!!!!! Not to mention you'll have cooler surface temp.
Old 02-07-2005, 09:27 PM
Bo White's Avatar
Jet Hot....1-800-HEADER9
Old 02-07-2005, 09:30 PM
jrp
SN95 Director
jrp's Avatar
pics of said custom hearders?
Old 02-08-2005, 09:05 AM
I'll put some on tonight when I get back to my computer.
Frank
Old 02-08-2005, 11:30 AM
snketr's Avatar
SWAINTECH!!! We drove from South Carolina to St Louis MO and I reached in and grabbed my friends stainless works headers. After driving for 10 hours!!!!!!!!! That **** is amazing!
Old 02-08-2005, 04:27 PM
GuitsBoy's Avatar
Why?
Old 02-08-2005, 04:47 PM
cyphur's Avatar
Originally Posted by GuitsBoy
Why?
I second that question...what could possibly urge you to grab headers after more than 20 mins of use? are you mad?
Old 02-08-2005, 08:17 PM
I attached a few pix of the drivers side. It's not done yet but it's tacked together and ready to tig up.
Frank
Attached Thumbnails Just built custom headers, Who has the best coating?-header-pic-1.jpg   Just built custom headers, Who has the best coating?-header-pic-2.jpg   Just built custom headers, Who has the best coating?-header-pic-3.jpg   Just built custom headers, Who has the best coating?-header-pic-4.jpg
Old 02-08-2005, 08:24 PM
DavidNJ's Avatar
HPC and Swaintech are generally the ones with the most elaborate coatings. Airborne and JetHot are also there, however I don't hear about JetHot much in oval track racing. That may just be my area or track though.
By the way, in carb oval racing you are forever getting at the plugs. Coating helps alot! Although I wouldn't grap it.
David
Old 02-08-2005, 08:45 PM
ddelallata's Avatar
holy ****! the ceramic coating on my PaceSetters gets crazy hot even after a few seconds of idling in my garage.
Old 02-08-2005, 09:02 PM
snketr's Avatar
I grabbed them because we opened the hood at the gas station just to check everything over and I didn't notice any heat coming off the motor when I leaned in. So, I was like holy crap! I tapped the header and it wasn't hot, then I grabbed it and held for about 4 seconds until my hand got hot. Very sceintific experiment. Conlusion: Swaintech is the ****. Andy
Old 02-09-2005, 02:57 AM
jrp
SN95 Director
jrp's Avatar
nice, 1 3/4?
Old 02-09-2005, 05:20 AM
1 7/8"
Old 02-09-2005, 08:40 PM
S2002S's Avatar
I have Airborn coating on my headers and so far, so good.
www.airborncoatings.com
Old 02-10-2005, 12:52 AM
Richiec77's Avatar
I'd say HPC. Jet Hot is Good, but HPC is better. Just look at who uses Jet Hot and Who uses HPC. (Jet Hot-Street. HPC- F1, NASCAR,etc.)
I'll copy a quote I had from them.
HiPerCoat
Strip charge to remove oil, rust, carbon, paint, etc., (this only
applies to
used components)
$20.00
V-8 "street car" headers (must have a 2,3 or 4 bolt flange on the end
of the
collector)
$165.00 High luster aluminum in appearance, outside only coating
$220.00 High luster aluminum in appearance, inside and outside
coating
$214.50 Semi-gloss black in appearance, outside only coating
$286.00 Semi-gloss black in appearance, inside and outside
coating
HiPerCoat Extreme
applies to
used components)
$20.00
V-8 headers
$750.00 Semi-gloss black in appearance, inside and outside
coating.
Here's a link
http://www.hpcoatings.com/
I am still thinking about coating my Edelbrocks and I'll have them do it.
Old 02-10-2005, 12:54 AM
Richiec77's Avatar
Frank
Those look like a set I saw being made in a magazine a little while back. Building a set for a Chevy II Nova. Was that you???
Old 02-10-2005, 02:49 AM
GTS346's Avatar
Mate u got it easy, so much room there, 1 7/8" pipes and there is no obstructions in your path.
I wish mine was half as easy, we had to go 1 5/8" as nothing bigger would fit due to space limitations and we need to raise the motor out every time we move on to the next pipe when bending etc.
Should flow very well, job well done mate.
Quick Reply: Just built custom headers, Who has the best coating?
