98 temp sensor in 00???
seeing has how the 98 cars had the only functional coolant temp sensor gauges do you guys think it would be as easy as changing the sending unit???
i figure it couldnt be the sensor on the block because the PCM still needs to have an accurate number to calculate everything. any ideas???
