oil temp gauge
I think that you need an oil filter plate from a corvette to do this. Or you can also make a hole on your f-body oil filter plate. Others will give you more info but I thought that I'd give you a heads-up.
Yeah you have to drill and tap the plate right above the oil filter. It looks like a small t'stat housing, it has two 10 mm bolts holding it in place. Have a catch pan ready cause you will lose a little oil. If you want more info, just PM me cause I just run a oil temp gauge on my SS last weekend.
yep......just drill and tap that little thing....
Originally Posted by Y2K SS
thanks harrison. Would you happen to have any pics of it. I think I know which one it is. Its basically thye one bolted to the block and the oil filter goies to that right.
http://www.xse.com/leres/ss/gaugepod.html
