THE COMPLETE VIDEO/SOUND 4 clip :idle,revs inboard,music from the outside,cruise in 6
Old 02-18-2005, 11:48 PM
miami993c297's Avatar
Default UPDATE/THE COMPLETE VIDEO/SOUND 4 clip :Idle/Inboard/WOT outside/Cruising
VIDEO + SOUND : idle, revs inboard, music from the outside, cruise in 6th of my Z06 after mods & tune
that was just after the dyno session, since there the engine has break-in and the rev limiter is now set at 7200rpm, the car became just faster everywhere :
The first clip is idle @ 850rpm:
http://s28.yousendit.com/d.aspx?id=3...U21HLI21Z6TUCP
This one is Revs Inboard :
http://s28.yousendit.com/d.aspx?id=3...O1LTD90KGE44JQ
Now it's Music from the outside (longer) :
http://s6.yousendit.com/d.aspx?id=0O...V12NH7726DIM1A
you finish with Cruise in 6th @ 1100rpm :
http://s2.yousendit.com/d.aspx?id=31...R13YE9IKHIBJGV
When you are on the link you can right click and save
Have fun
Christian
this is the list of the mods:
Kooks 1 3/4" x 3" with Weld-On Collectors, Stainless Steel,
Kooks 3" x 3" Off-Road X-Pipe
SpringKit Precision Race Components Gold Spring Kit With
Titanium Retainers, Seats & Seals
Texas Speed & Performance Chromemoly 7.40" Pushrods
Rollmaster Double-Roller Non-Heat-Treated Timing Set for LS1
ASP Underdrive Crankshaft Pulley, 1997-03 LS1 Corvette
Donaldson Blackwing Induction Kit, 1997-2004 C5 & Z06
MSD 8.5mm Spark Plug Wires
NGK TR55 Spark Plugs
COMP CAM Grid #LS1 3722R/3720R HR16
Valve timming :
Open INT: 2- BTDC , Close INT: 46 ABDC
Open EXH: 48 BBDC , Close EXH: 8- ATDC
these specs are for cam installed @ 114 ICL
224/220, .581/.581 @ 116 lsa
Old 02-19-2005, 10:52 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Very nice.
Old 02-19-2005, 05:07 PM
One link has already shut down, download what you can and I will renew some video if necessary, let me know if you need one video that is shut down, I will send it by email.
Christian
Old 02-19-2005, 07:56 PM
link on Idle update @ 9pm
Old 02-20-2005, 08:29 AM
HavATampa's Avatar
The idling doesn't sound like much of a cam, I guess because of the 116 specs. But man, it sounds awesome when you opened it up. What mufflers are you running?
Old 02-22-2005, 08:09 AM
Hi HavATampa
The goal was to be as close as possible from STOCK drivebility & SOUND.
We are right on it.
The COMPROMISE was to go with Kooks 1 3/4" x 3" with Weld-On Collectors, Stainless Steel, Kooks 3" x 3" Off-Road X-Pipe but to keep from the Z06 the TITANIUM cat back.... that's the sound you are listening.
Christian
