What I need?
What I need?
I'm planning to install my hooker headers with a texas speed catted-y. Is it just installing the headers with gaskets and merging th y with the collectors? Will I need extensions of the o2 sensors or Will I need new ones?
The hookers should come with them, just installed my Hookers yesterday. Good luck- see https://ls1tech.com/forums/generation-iii-external-engine/280063-help-hooker-lt-post-install-bad-missfiring-02-codes-no-power-running-pig-rich.html
Originally Posted by MeentSS02
Just get some new OEM gaskets (as has been stated) or reuse the old ones (should work too), and O2 sims. I did the stage 8 locking header bolts as well, but it wasn't necessary.
So get new gaskets you said? That's it? Does the header kit come with anything? someone said extensions where do I get all this?
Kleeborp the Moderator™
Originally Posted by heymoej
hey, where do you get the stage 8 locking header bolts??????
Moderator
I think you'll be much better off buying new 'vette
rear O2s, than reusing stockers and buying extensions.
Headers make life difficult for the stock O2s with their
low heater power in the now-cooler exhaust gas. The
'vette rears come with nice long harnesses and plug
right in.
right in.
