First drive: Fast 90/90 - Hmm.
!LS1 11 Second Club
Just drove the car for 20 miles.
Revs hold at 1400-1500 rpms for about 20 seconds and eventually settle back down to 1000 (idle).
The car needs tuning for the new intake and exhaust setup (just about everything was swapped out- that's another thread altogether), it's relearning idle.
I don't want to point the finger at the FAST 90mm TB just yet, but it's looking like it's gonna act up/stick on me. I'll keep updating this thread.
!LS1 11 Second Club
Originally Posted by nspr8td lt1
damn, hope it works out for ya, and thanks again for the ls6
It did stick at 2000 rpm for a bit. But went back down. Maybe it's just idle relearn (I hope).
!LS1 11 Second Club
Originally Posted by DanZ28
Doesn't sound like idle relearn to me (mot how mine is anyway), I'd look elswhere.
UNDER PRESSURE MOD
ATAP the car and physically see what your throttle position is. If it is at 0%, then it would most likely be programming and not the throttle body.
The reason I say this is because I have the same issue. My rpm hovers around 2000rpm when I push in the clutch until I come to a complete stop then it returns slowly to 875 rpm idle.
I checked my throttle position and it is at 0.0% when I push in the clutch and coast to a stop, but the rpm hovers at 2k before coming back down.
Just an option to look at before sending it out.
!LS1 11 Second Club
I'm just a little quick to jump the gun on the TB sticking as I've been reading about many others sticking for months now.
It's at least good to know FAST was responsive to my call.
!LS1 11 Second Club
Originally Posted by JS
Up to .04% is fine on TPS and check the IAC counts (25 to 40) too.
Did u do the tweeks to the TB (Peen mod and redrill the shaft so the arm cant move)
If not u need to fix the TB...
Mine works flawlessly...
It reads .04% and 25 on the IAC
I'm currently putting break in miles on the clutch and rear, so tuning will occur next week. I'll take those IAC readings to the tuner with me.
The FAST TB is a piece of ****, plain and simple. I took mine off the other night, put the TPIS on, and it made a WORLD of difference. The throttle response was 100x better, and no more of that sticking BS. The extra money is worth it.
!LS1 11 Second Club
Originally Posted by Beast96Z
If you didn't drill the shaft, it is probablly spinning. A set screw in aluminum can't hold to much pressure, so you gunna need to drill the shaft. If not now, it'll happen later.
!LS1 11 Second Club
Joel they did redo the shafts,I saw a new one and it has been corrected at least on that one but the peen mod was not done.I never called Fast becuase they wont listen to a boob like me....
!LS1 11 Second Club
Originally Posted by white2001s10
Did you disconnect the battery for a while before the re-learn?
Drove the car to work again today with no idle issues.
I'm still going to do the set screw and peen mod when I have some free time this weekend.
I'm in contact with them now as they are working to resolve my problems. I'm providing them a couple of the threads that discuss the problems and solutions people have used.
