belt issue with asp pulley....
i recently installed a asp pulley.... i read before that ls1s are notorious for having the tensioner cause a problem with this belt.....in the case of my car since i installed the pulley whenever i race my car the belt comes off track and comes half off the tensioner and the power steering pulleys.... its on the right track still on the crank pulley.... do i need a new tensioner??? let me know guys thanks
yeah.... i dont know if i could put a smaller belt on it.... its pretty tight on there....but i guess at high rpms im guessing maybe the tensioner is moving causing it to slip off.... the crank pulley seems ok cuz both the serpentine and the air conditioning belts are staying on just fine there.... if its the tensioner i dont know if should buy the one from thunder racing....or just another stock replacement.... dont know if i could fit a smaller belt on there....that be nice since the thunder racing tensioner goes for 130 bucs
i heard from another guy from the other forums that your suppose to take out the alternator bolt.... how would this fix the problem????? anyone ever hear of this?? i ordered the thunder racing tensioner... but hopefully some insight on taking the bolt out of the alternator would work... let me know guys thanks
fyi, i had zero problems with mine ever commin off even spinnin 7k. id try a new factory tensioner, yours may be a lil bouncy with age.
Location: Used to live in South Texas, Now in North Carolina
I had the problem with my stock pulley. Car had about 70k on it at them time and I was turning about 6800 rpms. Doesn't relly mater now car the motor is trashed but when It gets running I already have a new tensioner to put on it.
Originally Posted by DanZ28
Mine did that with very few miles on the car after I did the H/C. I just put on the LARRY pulley and problem solved..
Dan
Dan
I bought the Katech pulley. It was a little pricey, but the two belts I shreded wasn't much fun either. I read somewhere on here of new stock tensioners doing the same thing. I didn't want to waste the time so I just got the Katech. It is a quality piece and it doesn't look too bad under the hood either.
Good luck with you decision!
yea man i dont know who told you that........lol................
Mine started to walk off the P/S pully after the first hard run. I installed a new belt thinking the one that came with the UD pully was defective. After installing the new belt I went directly to the track, made one pass & it was walking again. I had a wrech with me so I got the belt back on track & 50 or 60 passes later have had no other problems. I suspect when the belt is new it's weirded out from being in the packaging & needed a little stretch to settle in.
just did my pulley swap with a march pulley and it's walking off the tensioner and p.s. pulley as all you have said above... this was just driving around town.. first 2 days I had my car back on the ground.... and smelling burning rubber.. my car only has 34k miles on it so.... not high milage and non racing still had an issue... I'm gonna order the tensioner from thunder.. hope it fixes my problem and if not at least it looks good....
yeah buddy i ordered the tenseioner too.... hope it solves the problem as well... mine only comes off from taking the car above 6 k.... im pretty sure my pulley is on and seated properly....a lot of people think that my pulley isnt on all the way...but if this was the case the AC belt would walk too.... o well we'll see...
Originally Posted by chris2000ss
where did you get the larry pulley and how much $$
Dan
