autometer air/fuel after header install
those meters run off the PCM 02 signal right? well, alot of the time when you do LT headers the O2s are set further downstream in the exhaust system. This would mean if your O2s are lazy then your A/F meter won't be registering properly either. Does it not work at all or does it just hop around all stupid like? If it still works, how bout at idle, part throttle, WOT?
